flatspot
Re: flatspot
come on guys just because you won the cricket last week you can still answer an aussie
Re: flatspot
What carb is on it?
Re: flatspot
standard aisin carb
Re: flatspot
Apparently the choke flap/butterfly can get loose on them and not work well.
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: flatspot
Bun the carb. Get a replacement. Webber or SU.
- donkeychomp
Re: flatspot
I do like Jordi's idea but you could always strip and clean it...
Re: flatspot
They are famed for problems with the auto choke and idle up systems.
The easy option here is to fit a HIF44 SU but may not he so readalily available where you are.
As said check the choke flap isn't loose or sticking.
Check for air leaks or cracks in a vacuum pipework.
