I'd be tempted to disconnect the fan, then see if a stick of burning incense (or maybe a cigarette) can help you find the leak.Robert.m wrote:It still sounds like it is drawing air in somewhere from around the inlet side of the engine but can't find exactly where.
How fast ?
Re: How fast ?
Re: How fast ?
Got the speed issues sorted, the air leak was caused by a small hole in the manifold which should have been blanked off when the weber was fitted, did some port matching/smoothing on the manifold and carb adaptor plate, blew carb out, set valve clearances, set ignition timing to 10deg BTDC, fixed a dodgy HT lead, replaced fuel filter, replaced leaking breathers and folded the mirrors in , does mid 60's easily now fast enough to make the roof flap.
