Bling
Bling
Post by ScottieJ » Fri Sep 30, 2011 4:59 pm
this is almost porn :guns:
Re: Bling
Post by ROBBIE » Fri Sep 30, 2011 6:36 pm
what is it???????????????
Re: Bling
and dont say engine :lol:
Re: Bling
Post by turbo-tom » Fri Sep 30, 2011 7:27 pm
loooks similiar to a vit engine but im probably miles off hahaha
Re: Bling
Post by ScottieJ » Fri Sep 30, 2011 9:28 pm
It's just a 1.3 8v with gsxr carbs and a 1.6 8v head but a fawking sexy one!
Here's the specs
Motor: 1.3 .020 over and deck shaved,
           I used dish pistons because of the decking,
           1.6 Reynolds ported polished and larger valves and shaved head.
                             Caution: They are a bit hard to deal with.
           Isky cam Beware the cam timing sheet is incorrect. They use a 1.6 rocker ratio and it should be 1.3 ratio.
           I used Hawk Suzuki Cam 2 specs and that worked out great.
           Adjustable timing gear Because of the shaving of the head and block.
           I also had to make a custom timing adjuster wheel. It was to small in diameter and was unable to get the
           timing belt tight.
           Internals are balanced and flywheel,
           I'm going to try a Centerforce clutch this time.
The intake was made from a solid block of 6061. It started at 35 pounds when the machining was done it was 8 pounds.  I also decided to machine the water ports in the manifold. The carbs are 32mm Katana carbs. The external accessories on the motor I have also machined up. The distributor has been switched to mechanical.
I have started it and it runs great. This was a lot of trial and error with return line sizes and tuning.
The manifold was very time consuming so I would not make another.
Re: Bling
Post by turbo-tom » Fri Sep 30, 2011 9:37 pm
so do you know ho much bhp its kicking out :brows:
dominic
Re: Bling
Post by dominic » Sat Oct 01, 2011 7:13 pm
WOW wot a super sexy engine.
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
dominic
Re: Bling
Post by dominic » Sat Oct 01, 2011 7:15 pm
:rhinohump:
Dom
:smokin:
:hahaha:
Currently Drive
Karis
Re: Bling
Post by Karis » Mon Oct 03, 2011 3:06 pm
ohhhh dear. Scott i thought you had problems but... 'this is almost porn' reaaaaally?
Karis
2000 Grand Vitara 2.5 V6 :)
Re: Bling
Post by twiss » Mon Oct 03, 2011 3:19 pm
lol women just don't understand!!!
I'd rather look through a book of tuned G series engines than a porn magh :P
