235/75/15
charger
235/75/15
Post by charger » Wed Jan 04, 2012 1:00 pm
Will this tyre size be ok with a 2" add a leaf lift on stock rims.
Is 205/70 basically the same as the stock 195/80
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: 235/75/15
Post by ScottieJ » Wed Jan 04, 2012 1:29 pm
charger wrote:Will this tyre size be ok with a 2" add a leaf lift on stock rims.
205/70 = 26x8
195/80 = 27x7.7
So they are smaller but wider, not a worthwhile swap IMO
Highlander
Re: 235/75/15
Post by Highlander » Wed Jan 04, 2012 1:44 pm
Unless you've already got the tyres or picked them up cheap :lol:
charger
Re: 235/75/15
Post by charger » Wed Jan 04, 2012 1:51 pm
So should a 235/75 be ok with a 2" lift??
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: 235/75/15
Post by ScottieJ » Wed Jan 04, 2012 1:55 pm
235/75R15 = 28.9"x9.3" so yes should easily fit with 2" lift
Re: 235/75/15
Post by Edweird » Wed Jan 04, 2012 6:52 pm
You could almost get away with 235/75/15 without a lift couldn't you? You'd get some rubbage on lock so you'd need to do something about that.
Re: 235/75/15
Post by Tramp » Wed Jan 04, 2012 8:47 pm
I run 235/75r15, I have a calmini 3.5" lift, its just right for the tyre size with no rubbing
Re: 235/75/15
Post by twiss » Wed Jan 04, 2012 9:17 pm
I have 235x75r15 Kumho KL-71s on standard wheels... with about 2.5-3" lift, and wheel spacers.
I wouldn't really recommend it without wheel spacers, you will probably rub your springs on full lock
I think 3-3.5" lift is best with them as you have some room for articulation!
