Problem is it diff or prop shaft
Hi all im no good at mechanics but took my sj out today was in a mud pit and just lost all gears can select any gear and nothing is there i thought it was gear box gone but a mate rekons its the diff or prop shaft how would i no which 1 it is cheers
Re: Problem is it diff or prop shaft
If its a diff or prop shaft you would still have drive in 4wd as long as the front hubs aren't in free wheel.
Dan
Dan
I think they are free wheel
Well the prop shaft is easy enough to inspect. Check where it attaches to the transfer box flange and at the other end where it connects to the diff. Give it a good wiggle and try ro tate it.If its solid then that is that ruled out.
If you cant turn the prop with the truck in neutral on the ground then that proves your diff is ok.
Dan
Dan
After your other post it maybe that the clutch has had it. If it is worn and you filled it will muddy water it may have burnt out, although they will normally slip for a while before they give out.
Put the front hubs into the lock position - transfer box in neutral - (chock wheels) handbrake off - then go under and see if you can turn the front and rear propshafts. If you can't turn them more than a little we can assume your diffs are ok
Darrell im also sure the clutch would either slip for a bit or at least still have a tiny ammount of drag now.
Ok will check these and i dunno if it will be a clutch as i can put it in a gear and just start the car lile its in neatural dosnt try to bolt forward
I checked the propshafts they look like they connected fine and i cant turn either one by hand so does it look like gearbox or clutch ?
Sounds like clutch or gearbox to me!
Is there any change in noise when you use the clutch? I think you would hear the gearbox input shaft turning if the clutch was working
Hi no there is no change in noise and when i lift bonnet there is a strong smell of clutch but if i put it in gear and tried to start it wouldnt it try to bolt forward as mine dosnt i can put it in gear and start it as normal like its still in neutral
