Prop spacer needed
Prop spacer needed
Just put my rear springs on front and my prop is to short lol. Guess i need a spacer?
Anyone got a idea where i can get one front? Probley about 1 inch thick. Thx
Re: Prop spacer needed
I got one here http://www.bits4vits.co.uk/store/index. ... &Submit=Go
i might have a 1 inch one i will have to tell u later tho because havent got garage key if u are interested mate
- felstmiester
Apart from ruf is that all ? If so I find that weird cos I've gone ruf and moved my axle forward and I've not needed a prop spacer.
Just bought one from jimny bits which turned up next day about £45 posted and works a treat.
Axle moved foward a inch and defo needed a spacer but it does have extended shackles on it aswell (dont know if that made a diff)
- felstmiester
Shackles could be it then. I've got rascal rears and ruf but prop is ok. It's a little out more than standard but not enough to need a spacer.
argh nooooo not shackles!!!
aka spring killersturbo-tom wrote:Shackles aka fangs.
