The Bird Man
Post
by The Bird Man » Mon Jun 03, 2013 12:05 pm
Hi all, just wondering if anyone could help me out please. I need some new brake shoes but I the diameter of the drum is required to get the right ones, does anyone know this off my hand
Oh and it's SJ 410. thanks in advance
- The Boss
Post
by ScottieJ » Mon Jun 03, 2013 12:17 pm
There's two different diameters for spanish and Jap. problem is as well that there is a chance they could have been swapped since it left the factory.
The Bird Man
Post
by The Bird Man » Mon Jun 03, 2013 1:31 pm
So would I right in thinking that this is the part I should be measuring ? The part that holds the studs ?
- Brake drum.JPG (6.22 MiB) Viewed 4645 times
Post
by Jordi » Mon Jun 03, 2013 1:40 pm
You need the internal drum diameter i believe.
The Bird Man
Post
by The Bird Man » Mon Jun 03, 2013 1:59 pm
Is it just the four nuts holding it on ? As there is a ring of screw heads around it and it doesn't want to budge ! And I don't want to take of unnecessary parts. Thanks.
The Bird Man
Post
by The Bird Man » Mon Jun 03, 2013 2:16 pm
Got it off !! Is this what you mean by internal mate ?
- Brake Drum.JPG (4.86 MiB) Viewed 4639 times
dazerede
Post
by dazerede » Mon Jun 03, 2013 8:47 pm
Those are 100% Spanish brake drums which are 219mm
Here is the trouble I had
http://forum.suzukiclubuk.co.uk/vi ... ilit=drums
- IMAG0294.jpg (836.07 KiB) Viewed 4623 times
4” calmini lift kit
