Fuel return on SU and electric pump
The carb engines have a fuel return on the pump my electric pump doesn't.
Is it worth running a return from the carb over flow back to the tank?
Re: Fuel return on SU and electric pump
Saves pumping fuel onto the floor if the float ever sticks or can't hold the pressure.
Mine goes back to the tank.... yes
- timwilks13
- SCUK Website Padawan
As does mine....yes
Mine doesn't, but it most definately should!
I thought facet pumps are self regulating and therefore didn't need a fuel return pipe
I also thought a SU overflow pipe just hang down, out the way, you could also see if it was overflowing
V
V
Hell , what do I know
V
V
I just guessed it won't matter if it goes back to the tank. My overflow just goes to the floor.
- kibris
When i tried it on mine - it would not run right, especialy just after filling up, used to cut out and not start right pull the overflow off and it was happy.
Another thing to add to it when the new shell goes on.
- Edweird
Same here. I've just got a long hose down to the chassis where it's held in place with one of those cable wrap things my SJ seems to have all over the place.Anton wrote:Mine doesn't, but it most definately should!
