remove rear half shaft with bearings.......
courior
Re: remove rear half shaft with bearings.......
Post by courior » Sat Jul 26, 2014 9:07 am
Thats a good idea!! and looks pretty simple to make... i was thinking to get a big beer can and fill it with concrete and leave a tube in the middle to form the slide hole.. then when it sets drill the end out and use this as the weight for the slide but leaving it in the can for strength... and looks :)
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Post by twiss » Sat Jul 26, 2014 9:11 am
Sounds feasible! Although make sure you use a Monster can to annoy scottie ;)
Post by ScottieJ » Sat Jul 26, 2014 10:32 am
Not sure a can filled with concrete will work, can imagine the concrete will just break up when you use it.
courior
Post by courior » Sat Jul 26, 2014 4:34 pm
That's what I was thinking and hence why would leave it in the can. Can always try and see I guess. :)
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
