comfortable leaf spring shackles
steve greenc3
Re: comfortable leaf spring shackles
Post by steve greenc3 » Thu Nov 13, 2014 9:40 pm
They look very similar to calmini lift shackles, they have lifted my truck but the ride is no softer!!!
Post by ROBBIE » Thu Nov 13, 2014 11:20 pm
steve greenc3 wrote:They look very similar to calmini lift shackles, they have lifted my truck but the ride is no softer!!!
Is that the banana ones? as that is what I was thinking
Post by ScottieJ » Fri Nov 14, 2014 10:21 am
Edweird wrote:They're not braced in any way; I don't like them.
Shackles don't need braces??? i don't see the point in bracing shackles.
Also the banana shackles are only kinked so that they can allow a bit more droop travel before the shackle hits the shackle stop on the rear (if you have them fitted the right way) it does not matter what shape a shackle is, the only thing that effects how the shackle works is the distance between bolt centres in a straight line.
Post by ROBBIE » Fri Nov 14, 2014 1:07 pm
Don't need the banana ones if you cut the stops out ;)
trotter
Post by trotter » Fri Nov 14, 2014 2:07 pm
for scottie and dan
1 word...
plughs!
if in doubt, FLAT OUT!
Post by ScottieJ » Fri Nov 14, 2014 2:27 pm
trotter wrote:for scottie and dan
1 word...
plughs!
:hahaha: :hahaha: :hahaha: :hahaha: :hahaha:
