I'm back...
Lersman
Re: I'm back...
Post by Lersman » Thu Aug 29, 2019 6:43 pm
Can't get ARB compressor working so hooked a line to my workshop compressor @ 50psi and no engagement, lifted off the floor wheels still spin on opposite directions as norm. No air leak from outside of diff just a slight hiss from breather??
Lersman
Re: I'm back...
Post by Lersman » Thu Aug 29, 2019 6:47 pm
.... and now leaking oil seals 🤬
Re: I'm back...
Post by ScottieJ » Fri Aug 30, 2019 12:48 am
ARBs need around 70psi to engage but ARB recomends 100-150psi.
There shouldn't be a hiss from the breather and is the leak coming from the axle oil seals? if so the ARBS might need new O-rings on the end flange.
marve114
Re: I'm back...
Post by marve114 » Fri Aug 30, 2019 7:02 am
Lersman wrote:
Tue Aug 27, 2019 6:39 pm
Any chance of full access...? Pretty please.. as l need to clear some of these sj parts I've been hoarding and create some space?
What ya got ???
Lersman
Re: I'm back...
Post by Lersman » Fri Aug 30, 2019 11:31 am
5x 35"x12.5" bighorns on max offset black steel rims nearly new, sj lift springs, props with newish uj's, Vitara ps setup Inc wedge,d shackles,tin top rear door,413 calipers,discs,drums master cylinders, vit soft top, set of tatty Weller's,hif38 + adapter and inlet manifold etc...
Lersman
Re: I'm back...
Post by Lersman » Fri Aug 30, 2019 10:43 pm
I will up psi and have another go.. cheers
