oil seal gone?
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 10:06 pm
yeah its just passed the mot so the bearings are all good i believe , just dont feel that confident on doing it on my own :lol:
Re: oil seal gone?
Post by Darrell » Mon Jun 25, 2012 10:09 pm
Knuckle felts and seals are dealer only, but sometimes do appear on fleebay.
The axle seal any bearing dealer can supply or can be brought online.
Your knuckle seal looks in good condition and the felt comes in 2 half's.
If your driveshaft will pull straight out you don't need to remove the rear seal and kingpins.
(you could remove the lower kingpin just to get the oil out)
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 10:13 pm
Darrell wrote:Knuckle felts and seals are dealer only, but sometimes do appear on fleebay.
ahh okay thanks! , i know sometimes the is a seller on the bay that sells a complete axle kit all bearings seals felts etc for around about £60 for both sides i believe :lol:
Re: oil seal gone?
Post by Darrell » Mon Jun 25, 2012 10:21 pm
This shows all that's needed to get to the seal. Spindle off ,with hub attached, driveshaft still connected. The axle oil seal on it's own is only a few quid :thumbup:
http://www.acksfaq.com/samuraifrontaxle.htm
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 10:27 pm
okay thanks for that :thumbup: just got to find some seals and felts only worrying bit now is that its more expense :roll: :lol:
Re: oil seal gone?
Post by turbo-tom » Tue Jun 26, 2012 4:09 pm
hey guys again is this all the correct parts i need ?
https://www.bigjimny.com/store/index.ph ... 1a21174cff
Re: oil seal gone?
Post by ScottieJ » Tue Jun 26, 2012 4:18 pm
yes :thumbup:
Re: oil seal gone?
Post by turbo-tom » Tue Jun 26, 2012 4:25 pm
ScottieJ wrote:yes :thumbup:
thanks buddy :rockin:
Re: oil seal gone?
Post by Darrell » Tue Jun 26, 2012 6:47 pm
Does the jimny knuckle seal also fit the SJ. I see they don't use a felt but some other "Doofer!"
I see lots of jimny seals on fleebay but sod all just for the SJ. :er:
Re: oil seal gone?
Post by dan_2k_uk » Tue Jun 26, 2012 7:06 pm
Why do they say to cut the swivel seal and some also come pre cut? Mine streched over just fine even with the kingpin bearing races in place.
The swivel hub seal is for a jimny anyway isnt it?
Also if your current retainers are ok then no need to pay for that set as felts and seals are onlt £25 per wheel at Suzuki.
Dan
