Just fitted sammy axles but!!
Re: Just fitted sammy axles but!!
Post by dan_2k_uk » Thu Jan 03, 2013 11:52 pm
Just robbed this.. Shows it better than most other pics I could find with a quick search although the axle has obviously had other work done on it.
Would want extra work right out to the knuckles aswel as that big truss for a proper job.
And I guess its bigger perches to stop axle wrap?
Dan
Post by Jordi » Fri Jan 04, 2013 12:09 am
Thats is a seriously solid looking axles. Can't say i've ever seen that done before.
Post by dan_2k_uk » Fri Jan 04, 2013 12:10 am
Give me a crate of strongbow and a woodland and I bet I can bend it! :lol:
Post by Jordi » Fri Jan 04, 2013 12:15 am
Nah, im going with snap it!
felstmiester
Post by felstmiester » Sat Jan 05, 2013 6:05 pm
Cheers Dan. Better get the welder out again. Is there anyone in the uk who sells the gusset kits? Just googled it but couldn't find nothing in the uk.
Post by ScottieJ » Sat Jan 05, 2013 7:02 pm
Offroad armoury used to sell axle trusses, I would presume they still do???
My new axles I bought off tim pink are sleeved with 3" red band tube, think its got a 6mm wall then uses pipe caps for diff guards, here's one of his pics when he first did them, ill get a few pics next time I'm at the workshop.
One thing to note though, when you truss a suzuki axle I would take it very very slow! It's very easy to warp a suzuki axle welding it, literally just tack it on, let it cool, weld a tiny bit, go for a cuppa, weld a tiny bit more, leave it to cool, weld a tiny bit more, have a cig, weld a tiny bit more, have some lunch, weld a tiny bit more, have a cuppa etc. :lol: and don't run any long beads of weld, just and inch or so at a time.
Post by Jordi » Sat Jan 05, 2013 7:09 pm
Tidy looking job that one Scottie. What all the brackets for? Must be for a fairly modded Zuk?
Post by ScottieJ » Sat Jan 05, 2013 7:47 pm
That's the full float converted rear so has all the disc brake mounts off a front axle, hubs etc. the tabs are the shock mounts.
Post by Jordi » Sat Jan 05, 2013 7:54 pm
Ahhh, looks well.
rockwatt
Recommended Trader
Recommended Trader
Post by rockwatt » Fri Jan 18, 2013 7:12 pm
Few ideas for you
Swivel gusets
Trusses
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
