Oh yes I was going to take some pics of my ruined upside down rear springs!!!
They are absolutely trashed and a perfect example of why all extended shackles need to go in the bin!
Prop spacer needed
Re: Prop spacer needed
- turbo-tom
AKa bollocks.ROBBIE wrote:aka spring killersturbo-tom wrote:Shackles aka fangs.
Longer shackles aren't spring killers if set up correctly and the shackles aren't too long
Also if you run a samurai with the smaller diff flanges then a late 410 propshaft is a better and probably cheaper alternative to a prop spacer, they are around 1" longer than samurai props
3 inch over standard = spring killer as I found out with the ones that came with the SJ
That much over standard and it'll max out the shocksROBBIE wrote:3 inch over standard = spring killer as I found out with the ones that came with the SJ
