Tom's starter motor dilemmas
Re: Tom's 85' SJ413 Build Rest in peace PILE OF CRAP!!!!!!!!
Post by turbo-tom » Fri Jul 05, 2013 9:05 pm
Right oy cheers for the help! She has fired up this evening once... I have spark, ign, fuel up the carb... When I turn the engine over by hand then try and start it she goes first time so I think its possible a worn fly wheel? Maybe :er:
suzukisteve
Post by suzukisteve » Fri Jul 05, 2013 9:10 pm
hmmmm, i wouldn't think so if its turning over as normal. ok so back to basics with the rule of kiss (keep it simple stupid) its a handy rule for me.
so spark.. check
fuel... check
air... check?
contacts and rotor arm/ cap all clean and ok?
pickle power!
Post by turbo-tom » Fri Jul 05, 2013 9:37 pm
haha kiss works for me aswell! but not this time. Yes right turning it over normal just sounds like its trying to turn over the engine but its not(starter motor is engaging though) . Turn the engine 1 turn over by hand and it will fire up with the starter motor like normal and then when you turn off the engine you have to repeat the above...
I think when it fired up this evening i was just lucky!
and Yeah checked all what everyone has said :)
Post by turbo-tom » Tue Jul 09, 2013 5:48 pm
Back to square one got fack all againfrom starter motor but everything else is fine :pissed:
mk1joe
Post by mk1joe » Tue Jul 09, 2013 7:15 pm
thats a shame mate:( didnt you say you got a new starter in it?
have you tried checking the feed to the small wire when you turn it over?
Post by ScottieJ » Tue Jul 09, 2013 7:32 pm
Get the starter out for a good strip and clean then :thumbup:
Post by Jordi » Tue Jul 09, 2013 8:11 pm
Starter out. Bench test it.
Are all the wires running to the starter ok?
Post by turbo-tom » Tue Jul 09, 2013 8:19 pm
Ive done all that strip ot all down cleaned it benched it last time worked fine now fack all
Post by Jordi » Tue Jul 09, 2013 8:27 pm
Have you checked all the wires to it are ok? No breaks or corrosion?
Post by turbo-tom » Tue Jul 09, 2013 10:02 pm
Tried all that buddy with multi meter checking all the resistance and all is fine.
