oil grade for su
Re: oil grade for su
Post by Tramp » Fri Sep 13, 2013 11:07 am
I've got an old mini manual and it says use 10w40,
timwilks13
SCUK Website Padawan
Post by timwilks13 » Fri Sep 13, 2013 11:26 am
saw a thread on another website where one guy was using 90w marine oil (which is way too thick) but yea just what you got lying around.
Post by Edweird » Fri Sep 13, 2013 11:32 am
You ask a hundred times you'll get a hundred different answers. I used automatic transmission fluid.
suzukisteve
Post by suzukisteve » Fri Sep 13, 2013 11:46 am
jobs a good un then! find whatever you can whack it in and away you go!
pickle power!
Post by ScottieJ » Fri Sep 13, 2013 12:30 pm
ScottieJ wrote:Straight sae20 is what the burlen stuff is :thumbup:
Sae20 is the recommended grade from SU so for the best performance you should use that. Engine oil is too thick in cold temps for the correct piston dampening, I could really notice the difference in power during winter running engine oil, the thicker the oil the slower the piston rises, therefore the engine will not be getting all the air it needs fast enough.
Likewise too thin and the piston will rise too fast causing a lean mixture during acceleration, therefore to avoid flat spots you will have to run a richer mixture to have a 'correctly tuned carb'
Essentially you can tune it to run with whatever oil you put in but the way I see it is why use anything other than what the manufacturer of the carb recommends :thumbup:
red 3in1 is too thin (think it's around sae10)
blue 3in1 is sae 20 so a good option
brake fluid is too thin
suzukisteve
Post by suzukisteve » Fri Sep 13, 2013 1:33 pm
hmmm I wonder if I could find something at work I could use... gimme a sec, tea first!
pickle power!
Post by Edweird » Fri Sep 13, 2013 5:05 pm
suzukisteve wrote:hmmm I wonder if I could find something at work I could use... gimme a sec, tea first!
I had to reread that. At first I thought you were going to put tea in your carb. :hahaha:
dazerede
Post by dazerede » Fri Sep 13, 2013 6:19 pm
What about atf fluid
4” calmini lift kit :)
Post by dan_2k_uk » Fri Sep 13, 2013 7:11 pm
To summarise....
OIL
Post by Edweird » Fri Sep 13, 2013 7:59 pm
dazerede wrote:What about atf fluid
Yeah, that's what I've got in mine.
