- The Boss
Post
by ScottieJ » Mon Jan 20, 2014 9:51 am
nice work
I think my most comical moment was when I was doing up a shackle bolt with two spanners, one slipped off the bolt and managed to catapult into my face, re-chipping one of my front teeth....still haven't had it repaired again
ferris
- Suzuki Guru
Post
by ferris » Mon Jan 20, 2014 10:22 am
Quite often at work when stripping back cables iv slipped and punched myself in the face. You would think i would have learnt to not pull towards my face by now.
Post
by Anton » Mon Jan 20, 2014 1:31 pm
My most recent attempt at an SJ based Darwin Award was undoing the drain nut on my transfer box. Skinned my knuckles and punched myself in the face at the same time - and HPOC Scottie saw the whole thing.
Minutes later I hit myself in the face with a 3/8ths ratchet while undoing the drain nut on my front axle...
muddymesser
Post
by muddymesser » Thu Jan 30, 2014 4:16 pm
ive smacked myself in the nuts with a breaker bar when a bolt snapped . . . think i was taking my springs off at the time
ben_moto501
Post
by ben_moto501 » Fri Jan 31, 2014 8:07 pm
On my old Sj I undid the bolt and removed the spring that holds on the wing mirror (plastic type). For some reason it just wouldn't come off, so I pulled and pulled, I didn't want to use a hammer as being plastic it might crack, it popped off while I was pulling and it went straight across my nose! Had a nose bleed that lasted about an hour! All was ok though, no body saw!
Post
by twiss » Sat Feb 01, 2014 10:30 am
ScottieJ wrote:
nice work
sorry about the late reply to this but the brake disc to the face needs to be mentioned here
muddymesser
Post
by muddymesser » Sat Feb 01, 2014 11:17 am
dont pictures exist of the brake disc to the face incident ?
Post
by twiss » Sat Feb 01, 2014 11:20 am
as requested
muddymesser
Post
by muddymesser » Sat Feb 01, 2014 12:10 pm
erm
am i the only one who tried to wipe the dirt off the screen
