Tramps Truck,
Re: Tramps Truck,
Post by Tramp » Fri Aug 08, 2014 6:21 pm
So, I know this has been a long time coming but I have actually done something constructive on my suzuki today, cutting and welding!!!! First thing first, I chopped out the rusty sill -
Then I was going to weld some metal in, but I didn't have enough, I did have an old DVD player body though and that donated some metal to make a patch in the front drivers side arch - the spot in question had a rotted steel rectangle over it, the rectangle long gone you could see straight into the cavity between the panel skins, so I patched as best I could,
"Holy pigeon shit batman'
Fixed, not perfect but will do for now,
I only made a few mistakes,
A little arc eye, a burnt finger and a blister on my thumb from the tin snip hinge!
So back to my sills, what thickness metal do I need to fix it?
Re: Tramps Truck,
Post by ScottieJ » Fri Aug 08, 2014 6:38 pm
I usually use .8/1.0/1.2mm cheap enough for a sheet from a metal supplier so I would just buy a sheet, much better to work with.
Nice work! Keep it up!
Re: Tramps Truck,
Post by twiss » Fri Aug 08, 2014 8:42 pm
I'm using filing cabinet its working nicely ;)
Re: Tramps Truck,
Post by Jordi » Fri Aug 08, 2014 9:25 pm
ScottieJ wrote:I usually use .8/1.0/1.2mm cheap enough for a sheet from a metal supplier so I would just buy a sheet, much better to work with.
I was using 1.5, bit trickier to weld to body panels, but I managed. Ideal for floor and bulkhead panels.
It's not too easy to work with curve/roll/fold but I solved that by finding an excellent sheet metal fabricators at very good prices.
Hoping it will also last longer as it will take longer to rust through, lol.
Re: Tramps Truck,
Post by ScottieJ » Fri Aug 08, 2014 10:46 pm
I do sometimes use 1.6 depends what part of the body I'm working on, generally try to match the thickness of the existing panel.
Or sometimes just depends what sheet I have lying around at the time :lol:
Re: Tramps Truck,
Post by dan_2k_uk » Sat Aug 09, 2014 10:42 am
Electrical panel doors are the one. Never walk past a metal skip at work without having a peer in for a few of those bad boys. Come in a range of thicknesses too.
Re: Tramps Truck,
Post by Jordi » Thu Oct 30, 2014 10:47 pm
We all know how the volvo is Luke, what's the progress on the Zuk?
Re: Tramps Truck,
Post by Tramp » Mon Jan 05, 2015 9:43 pm
Merry Christmas me.....
I need to get the gas bottle filled but...... I've got the stuff to get me going, I also bought x2 lengths of 1.5m 80x80x3 box section, good bye sills and hello box section!
Re: Tramps Truck,
Post by Jordi » Mon Jan 05, 2015 10:13 pm
Get on it!
Re: Tramps Truck,
Post by dan_2k_uk » Tue Jan 06, 2015 9:48 am
Good lad. Once you start you won't stop! Hopefully...
