Pump ?
Re: Pump ?
Post by ROBBIE » Sun Dec 14, 2014 7:35 pm
Filter? give it a clean, might become obvious
Re: Pump ?
Post by Darrell » Sun Dec 14, 2014 7:42 pm
Yes that's the fuel filter.
As far as I can see your looking for what was/is the pink & black wire.
Vitara SPI Wiring.jpg (678.33 KiB) Viewed 4317 times
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sun Dec 14, 2014 8:27 pm
thanks Darrell,that mean I don't need a filter then,, when I went today and had a look there were a few pink wires, but I have bean doen a bit lookin about n its the relay with the green plug going into it so I will check for the pink/black wire on that one , thanks mate
Re: Pump ?
Post by Darrell » Sun Dec 14, 2014 8:42 pm
You will need a fuel filter.
Injection systems normally use a filter after the pump.
I don't know if you could use the original filter before the new pump but I doubt it.
Yes the fuel pump relay is a green plug :thumbup: .
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sun Dec 14, 2014 8:54 pm
righty o I shall sort one of them out aswell , spot on mate thanks for the help hope to get it all sorted this week
Rhinoman
Re: Pump ?
Post by Rhinoman » Sun Dec 14, 2014 10:51 pm
The fuel pump relay and main relay are the same, the fuel pump relay has the pink wires. The relays are usually marked 31850-80C10, which is actually a Samurai part number but they are a common part.
