How fast ?
Re: How fast ?
Post by Anton » Wed Jun 21, 2017 4:29 pm
Robert.m wrote:It still sounds like it is drawing air in somewhere from around the inlet side of the engine but can't find exactly where.
I'd be tempted to disconnect the fan, then see if a stick of burning incense (or maybe a cigarette) can help you find the leak.
SlimGrim
Re: How fast ?
Post by SlimGrim » Wed Jun 21, 2017 5:20 pm
Good shout
___________________
Robert.m
Re: How fast ?
Post by Robert.m » Wed Oct 04, 2017 12:49 pm
Got the speed issues sorted, the air leak was caused by a small hole in the manifold which should have been blanked off when the weber was fitted, did some port matching/smoothing on the manifold and carb adaptor plate, blew carb out, set valve clearances, set ignition timing to 10deg BTDC, fixed a dodgy HT lead, replaced fuel filter, replaced leaking breathers and folded the mirrors in , does mid 60's easily now fast enough to make the roof flap.
