Samurai body parts, prices on last page
Re: Samurai body parts, prices on last page
Post by ScottieJ » Wed Aug 17, 2011 4:06 pm
Christoff wrote:No a local supplier called Bodicar, also got the same prices from another local called Autorads. They must have the same book
Not bad prices but id need to fabricate a way of fixing the rear arch flares on if i get 410 rear wings
drill out the spot welds to remove the original arch mount and then weld it back on using the holes you just drilled out :thumbup:
Christoff
Post by Christoff » Wed Aug 17, 2011 4:29 pm
Yeah is it called plug welding?
What are the odds I remove the arch and there's no metal left behind it though? I bet that lip is quite badly corroded.
Post by dan_2k_uk » Wed Aug 17, 2011 4:37 pm
you can see how bad they are from the inside. where the inner arch meets the wing it forms a V shape which will probably be rotten.
Shaun
Post by Shaun » Thu Aug 18, 2011 12:03 am
Do they do front wings? I'm thinking of just cutting my rotten sills out and putting some box steal in and making some rock sliders.
:edside:
