Hello from Essex coast
Re: Hello from Essex coast
Thats about the biggest for those rims i think.
According to the tyre size guide they should actually be on bigger rims. http://forum.suzukiclubuk.co.uk/vi ... f=14&t=226
- Sj410red
Ok thanks for that, so it's wider rims then for the next set of tyres
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
On 3" lift springs you should be ok for 31s without those shackles. Probably require a few inches off the bulkhead though.
- Sj410red
Sorry, few inches off bulkhead? Sounds like some welding to me?
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Sj410red wrote:Sorry, few inches off bulkhead? Sounds like some welding to me?
Yeah, 31s need more room or big bump stop extentions.
I think something like a 30/9.50/15 (is that the same as a 235?) goes on with a little lift and the bulk head seam folding over. Any bigger and its either the grinder and welder or a spot of axle moving.
im breaking a samiSj410red wrote:I have got 2 extended bump stops still to fit, they came with the springs, the tyres fitted are 235/70/15 on standard 5.5j rims but I would like to add larger tyres, anyone know what max tyre size can fit to my rims are?
at frinton on sea
pm me a number and your welcome to pop over
(ive a lovely set of tyres)
And Sj410 red you also have a lovely set
Ha ha, all the tact and finesse of a used car salesman. Like it mate4x4rick wrote:im breaking a samiSj410red wrote:I have got 2 extended bump stops still to fit, they came with the springs, the tyres fitted are 235/70/15 on standard 5.5j rims but I would like to add larger tyres, anyone know what max tyre size can fit to my rims are?
at frinton on sea![]()
- Sj410red
Cool, u got any wider than standard rims? Wots ur Sami body like? I got a rolling chassis which needs a good body
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
