Page 4 of 4
Re: Spot light wiring
Posted: Thu Oct 25, 2012 8:49 pm
by Crisdolf
Alternator looks new will have to check it tomorrow,just 4 small spots on roof,any idea best way to check alternator ?
Posted: Thu Oct 25, 2012 8:56 pm
Use a multimeter across the battery, should read around 12.4 volts without the engine running and around 14.4+ volts with the engine running. What wattage are the bulbs in your spots?
Posted: Thu Oct 25, 2012 9:04 pm
by Crisdolf
55watt I think
Posted: Thu Oct 25, 2012 9:17 pm
With full beams and 4 spots the alternator should be putting out enough power as that is less than a 30amp drain and the stock alt has a 45amp output.
Posted: Thu Oct 25, 2012 9:25 pm
by Crisdolf
If the alternator wasn't charging wouldn't the dash light come on ? I'm off tomorrow so I get the meter out and hav a check
Posted: Thu Oct 25, 2012 9:35 pm
by Edweird
Crisdolf wrote:If the alternator wasn't charging wouldn't the dash light come on ? I'm off tomorrow so I get the meter out and hav a check
It might be charging....a bit; just enough to keep the warning light off.
Or the warning light might be dead too.
Posted: Fri Oct 26, 2012 11:05 am
by suzukisteve
is there an 'upgrade'/ higher output alternator that'll go on the sj without much hassle?
Posted: Fri Oct 26, 2012 4:11 pm
by Crisdolf
Well tested alternator and it wasn't charging so a quick trip to local sparky ,it now as new brushes and new bearing and it's back to 100% ,job sorted
Posted: Fri Oct 26, 2012 4:44 pm
by Crisdolf
suzukisteve wrote:is there an 'upgrade'/ higher output alternator that'll go on the sj without much hassle?
I think there is ,have a look at this 280745341670 on eBay
Posted: Mon Dec 23, 2024 7:02 am
by tomcat
I am looking to add both front spots and fogs wired for "road" use.
Developed my own 'simple' logic diagram which is attached.
Any comments, corrections appreciated. Thank you.
