Welding?
Newtomud
Re: Welding?
Post by Newtomud » Tue Nov 15, 2011 12:44 pm
Or sell it on ebay.
Edit.. Just had a look on ebay for reference and the big red water fire extinguishers are 9 litre.
Re: Welding?
Post by dan_2k_uk » Tue Nov 15, 2011 2:05 pm
Sounds about right. Think a 10L refill is about 45 quid for argon mix.
Newtomud
Re: Welding?
Post by Newtomud » Tue Nov 15, 2011 3:54 pm
dan_2k_uk wrote:Sounds about right. Think a 10L refill is about 45 quid for argon mix.
So approx 9 litres for £30 inc vat is cheap..
I got the sellers details from the http://www.mig-welding.co.uk" onclick="window.open(this.href);return false; forum..
They are http://www.jawel.co.uk" onclick="window.open(this.href);return false;
They have branches all over the midlands.
Bromsgrove 01527 835621
Burton upon Trent 01283 743700
Coventry 02476 637603
Dudley 01384 456069
Erdington 0121 377 6080
Smethwick 0121 558 6191
Stirchley 0121 471 3355
Tamworth 01827 261553
Wolverhampton 01902 736411
Oh and I've ordered a mig welder from machine mart...Pick it up on saturday :doublethumbs:
Re: Welding?
Post by ScottieJ » Tue Nov 15, 2011 4:11 pm
Ah jawel, that's where I get my automotive paint from :doublethumbs:
Newtomud
Re: Welding?
Post by Newtomud » Tue Dec 06, 2011 6:29 pm
So approx 9 litres for £30 inc vat is cheap..Not
Still researching but it appears that it depends on the level of fill or bar/pressure and these are only filled to 50 bar.. Other bottles can be filled to 230 bar.
Re: Welding?
Post by dan_2k_uk » Tue Dec 06, 2011 7:00 pm
The one i was talking about is filled to 200bar from south west gas.
Dan
Newtomud
Re: Welding?
Post by Newtomud » Thu Dec 08, 2011 11:12 am
dan_2k_uk wrote:The one i was talking about is filled to 200bar from south west gas.
Dan
So if I've got this right :er:
Your supplier sells you 10 litre @ 200 bar (£45) which is 2000 litres and at 10 litres per minute flow rate it would last you 200 minutes and cost 2.25 pence per litre?
Jawel will supply me with a 9 litre bottle @ 50 bar (£30) which is 450 litres and at the same flow rate would last for 45 minutes and cost 6.7 pence per litre?
If I've worked this out right? Yours is the much better deal. newtomud also newtowelding :weld:
Re: Welding?
Post by dan_2k_uk » Thu Dec 08, 2011 11:53 am
Im no expert but that seems correct.
I think you should look at a few other suppliers in your area and see what they have to offer
Dan
Re: Welding?
Post by ScottieJ » Thu Dec 08, 2011 12:06 pm
TBH I rarely run my gas on 10l/m you don't really need to unless its a bit draughty.
Newtomud
Re: Welding?
Post by Newtomud » Thu Dec 08, 2011 12:30 pm
dan_2k_uk wrote:Im no expert but that seems correct.
Dan
ScottieJ wrote:TBH I rarely run my gas on 10l/m you don't really need to unless its a bit draughty.
Your right Dan so I looked up south west and they have a supplier fairly near me in Kidderminster..I'll give them a ring :thumbup:
Scottiej I was using the 10l/m for a reference to give me and idea of the different welding times on each bottle..But you're right it might be a bit draughty as I've no garage :thumbdown:
