2013 SCUK weekender 17-18th August @ Wagtail
Re: 2013 SCUK weekender 17-18th August @ Wagtail
Post by dan_2k_uk » Tue Aug 13, 2013 10:24 pm
gp7186 wrote:Try kalimex k-seal ive used it with brilliant results as a temporary measure on my 1.3 cracked block .The block cracked just under the inlet manifold and was 30mm long and it sealed it no problem. In fact it was so temporary it lasted for a year till I changed the engine.
Either way hope all goes well
Thats exactly where its cracked. Right on the casting that sticks out that has the thread for the head bolt in it. I guesstimate it has cracked exactly in line with the bottom of the head bolt.
suzukisteve
Post by suzukisteve » Tue Aug 13, 2013 10:30 pm
so dan what exactly happened then? did it just go pop or what matey?
pickle power!
gp7186
Post by gp7186 » Tue Aug 13, 2013 10:31 pm
Must be a common fault cause ive seen some 1.6 engines suffer from it aswell. At first I thought it was the inlet manifold gasket leaking or rather hoped it was until I got my head under but the k seal worked a treat fingers crossed eh
suzukisteve
Post by suzukisteve » Tue Aug 13, 2013 10:34 pm
um chaps.... is wagtail anywhere near Penrith in Cumbria by any chance??
pickle power!
Post by Jordi » Tue Aug 13, 2013 10:36 pm
No why?
suzukisteve
Post by suzukisteve » Tue Aug 13, 2013 10:37 pm
never mind its like 3 and a half hours away :-(
pickle power!
suzukisteve
Post by suzukisteve » Tue Aug 13, 2013 10:38 pm
its just that's where im on holiday at the mo
pickle power!
Post by dan_2k_uk » Tue Aug 13, 2013 10:40 pm
gp7186,
It is a 1600.
Steve,
I just got under it tonight to give it a once over and noticed the front diff and sump were soaked in coolant.
Strange thing is that it is so fine a crack it only leaks when under pressure but there is no sign of it having happened while I was moving as it is just a stain from it flowing with gravity (no wind) so I can only assume it cracked as it was cooling after the last time I used it but while the cooling system was still hot enough to be under pressure.
The postcode for Wagtail is on the first post.
Post by Jordi » Tue Aug 13, 2013 10:41 pm
suzukisteve wrote:its just that's where im on holiday at the mo
Centerparcs? Cos there is f'all else at penrith.
Post by ScottieJ » Tue Aug 13, 2013 10:48 pm
Dan I have a 100% runner of a 1.6 apparently but it has a slight smoking habit, we could throw it in thurs night/Friday morning if all else fails :lol:
