transfer box shake
vit4x4
transfer box shake
Post by vit4x4 » Wed Jul 02, 2014 6:09 pm
hi I have a sj blitz, when in 1st & 2nd gear the transfer box lever jumps about a lot, in the rest off the gears its fine, ive recently changed the transfer box so the mounting rubbers aren't damaged, is this normal?, thank you michael
Re: transfer box shake
Post by ScottieJ » Wed Jul 02, 2014 6:36 pm
Remove and check your engine mounts, the passenger side ones are the most likely to fail. Also check the UJs on the intermediate propshaft.
vit4x4
Post by vit4x4 » Wed Jul 02, 2014 7:02 pm
thank you scottiej will check that
Post by Edweird » Wed Jul 02, 2014 9:03 pm
Could be a defective mount. When one went on my T-box it would jump around whenever torque was applied.
NylonAdmiral
Post by NylonAdmiral » Thu Jul 03, 2014 8:47 am
I've had that same problem twice. Exactly as Scottie & Edweird say, one time it was one of the T-box mounts and the other time it was a UJ on the intermediate prop. Good luck!
vit4x4
Post by vit4x4 » Thu Jul 03, 2014 8:32 pm
thank you again for the help & advise, really is a friendly forum
