Jimny JB23 ecm wiring diagram needed!
Posted: Mon Jul 14, 2014 2:54 am
Hi all,
I have a JDM Jimny JB23 engine/trans (K6A, 660cc turbo, 5 speed) that I purchased off Ebay here in the states.
It came with the ECM and most of the wiring harness, but the wiring was pretty chopped up when they pulled the engine.
I am in the process of installing the engine in a '72 LJ10, replacing the existing 2-stroke 360cc twin that has a failing crank. I wouldn't be replacing this engine, but I am unable to find sufficient parts to rebuild it.
Anyways, I have not been able to find any wiring diagrams for the K6A engine used in the JB23 model. I believe that besides Japan, they were also sold in the U.K. Maybe the later model Suzuki Cappucino would also have basically the same wiring between the ECM and the engine.
Is there anyone out there that can help me with this? I am in desperate need of a good wiring diagram, because I am in the final stages of installing this engine.
Thank you in advance,
Tom H.
Tom H.
