Axle Identification 410 or 413?
dazerede
Post by dazerede » Fri Feb 08, 2013 7:22 pm
i was just wondering as i bought a set of axles a while back and im not sure if there 413 or 410 is there any chance of finding out without taking out the diff
as i swapped my front axle as it was cheaper than buying new seals and bearings
4” calmini lift kit :)
Re: SJ axle info
Post by Darrell » Fri Feb 08, 2013 7:43 pm
You could give this a try. The more tyre revolutions you do the more accurate it would be, but as long as you divide the driveshaft revolutions by the tyre revolutions your be fine :thumbup:
You may need a hand to count it though :D
Click Here for Youtube Video
dazerede
Re: SJ axle info
Post by dazerede » Fri Feb 08, 2013 7:57 pm
umm worth a try chears darrel
thats my plan tmoz afternoon
Re: SJ axle info
Post by Darrell » Fri Feb 08, 2013 7:59 pm
Not as easy as I though :er:
dazerede
Re: SJ axle info
Post by dazerede » Fri Feb 08, 2013 8:08 pm
yes the secound one made it alot clearer
chears darrel
Re: SJ axle info
Post by ScottieJ » Fri Feb 08, 2013 10:44 pm
dazerede wrote:i was just wondering as i bought a set of axles a while back and im not sure if there 413 or 410 is there any chance of finding out without taking out the diff
The diff carrier is physically bigger on 413 axles you should be able to see the difference by eye but if you measure the face say where the diff bolts into the axle say between the top and bottom bolts the. you'll see if what you have are 410 or 413 axles.
I presume they are the same width as your existing axles? All the parts apart from the diffs themselves are interchangeable between 410 and 413 axles. :thumbup:
dazerede
Re: SJ axle info
Post by dazerede » Sat Feb 09, 2013 7:44 am
Wright just measured the diff size and they are about 17-18mm about the same
But I will do the spin thing later
I have just realized that I have stripped the .410 front axle ages ago and only have diff and shafts left
So hopefully this us a 410 axle
Re: SJ axle info
Post by ScottieJ » Sat Feb 09, 2013 10:53 am
17-18mm? that's a bit small for a diff :lol: how exactly did you measure it? The length from the diff mounting face to the pinion flange is also different on 413 diffs they are longer than 410 diffs
dazerede
Re: SJ axle info
Post by dazerede » Sat Feb 09, 2013 11:13 am
I meant 170-180 mm or 16 3/4 inches
Just cane back from work and will have dinner and I shall compare it to my 410 diff
Re: SJ axle info
Post by ScottieJ » Sat Feb 09, 2013 11:24 am
:lol: I had a feeling you might've missed a 0 :lol:
