Manual hubs.
shaun donaldson
Manual hubs.
Post by shaun donaldson » Tue Dec 08, 2015 9:46 pm
Hi,ive just fitted avm manual hubs to my jimny,i wondered if I have done it right,i took the original black case off,then put the gasket on,then bolted black back plate with new bolts and washers[that were in pack]on,then screwed outer silver bit with switch on,does that sound right or have I missed something,and does anyone know or even better show me a picture of how I plug vacuum hoses please.
Re: Manual hubs.
Post by ROBBIE » Tue Dec 08, 2015 10:33 pm
Sounds about right. I fitted aisin on mine, they had to have a spacer fitted, but was basically the same thing
zook123
Re: Manual hubs.
Post by zook123 » Wed Dec 09, 2015 10:28 am
If i'm right in thinking, the vacuum system is redundant once you fit Manual Hubs, just block the ends of the vacuum system off with a nail, this will make the 4WD light stay on and not flash.
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
shaun donaldson
Re: Manual hubs.
Post by shaun donaldson » Wed Dec 09, 2015 9:09 pm
Thanks for the info,the slight problem I have is one of the hoses was sheared off where the rubber piece joins to a really rusty piece and is a right mess,so do I just try and plug every hole I can find?
Re: Manual hubs.
Post by ROBBIE » Wed Dec 09, 2015 10:37 pm
:oops: I didn't do anything with my vac pipes, they weren't working any way
zook123
Re: Manual hubs.
Post by zook123 » Thu Dec 10, 2015 8:27 am
I'll be honest, I haven't looked to see how they work on mine, but I know they're there as it's 100% standard complete with Rust!
The Hoses from the hubs need nothing changing, but you will need to make a mod from the vacuum tank
I think you need to loop the pipe on the chassis on the rear of the drivers side trailing arm loop it back to its self
and the same in each hub at the top by the king pin, then plug with a thick nail/screw
Re: Manual hubs.
Post by ROBBIE » Thu Dec 10, 2015 8:47 am
Cheers I'll look into that
shaun donaldson
Re: Manual hubs.
Post by shaun donaldson » Sun Dec 13, 2015 3:43 pm
Okie cokie,just down from the battery there are 2 small rubber hoses,ive blocked them off with a screw in each of them then some sealant over the top to make sure and hey presto when I engage 4 wheel drive, constant green light.
Rhinoman
Re: Manual hubs.
Post by Rhinoman » Sun Dec 13, 2015 9:37 pm
The vacuum actuator was hanging off mine so I removed them and used the T-piece to connect the remaining lines together. I then just blocked off the pipe from the manifold. I cut off the vacuum sensor and connected the wires together:
zook123
Re: Manual hubs.
Post by zook123 » Mon Dec 14, 2015 8:24 am
Woo! I feel helpful!
