Transfer Box Leak
zook123
Transfer Box Leak
Post by zook123 » Mon Mar 28, 2016 8:34 pm
Right, got a small leak of Transfer Box oil coming out around the rear prop mount to the box, from what I can see I will be able to do it on the Truck, but, the kit comes with three seals, so that would be the front, rear and the little one at the top, if it's leaking from one, is it worth doing all, or just the ones I need?
Also, i've got quite a bit of movement on the bushes, so i might replace them, is it simple to drop the box down and out?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: Transfer Box Leak
Post by ROBBIE » Mon Mar 28, 2016 10:43 pm
Yeah well simple, think it takes about half hour on mine, I have to drop the guard as well. Undo props, remove gear nob then the three bots on the mounts. Same as doing an SJ
