Rear interior 'door cards' over the wheel arches?
Posted: Wed May 11, 2016 8:21 am
by Phillips321
Hi guys,
My SJ410 is just bare metal in the back but i wanted to add some form of 'door cards' (if i can call it that) over the wheel arches and flush with the body. Has anyone here built and storage in the back of their soft top SJ? I'm looking for ideas and also what was originally there so i can figure out mounting options.
Many thanks
Re: Rear interior 'door cards' over the wheel arches?
Posted: Wed May 11, 2016 8:44 am
by SherwoodNash
I used the 2 x original hardboard 'panels' as templates and re-built using faux dark gray vinyl stapled over 6mm plywood and fixed using S/S black self tappers.
If you get stuck, I can post you some correct size paper templates
Posted: Wed May 11, 2016 9:11 am
by Anton
I'm thinking about lining mine, and then putting the card on a hinge to make storage...
Posted: Wed May 11, 2016 9:27 am
by SherwoodNash
Good idea
load's of useful stash space behind there.
Posted: Wed May 11, 2016 9:32 am
by zook123
Until it rots away and your kit falls out!
Posted: Fri May 13, 2016 11:16 pm
by Anton
Mine doesn't rot, I cured all the rot back there a long time ago, and I keep an eye on it!
SherwoodNash: I was thinking of keeping a full toolkit back there one side and spare fluids, bulbs and fuses, and a jack the other side. Maybe even some spare parts - a pair of driveshafts for breakages when offroad might be cool!
Like you say, there's masses of room behind there!
Posted: Mon May 16, 2016 4:57 am
Anton wrote:Like you say, there's masses of room behind there!
There would be in yours if it wasn't all dented and bashed up, probably lost quite a bit of space there
Posted: Mon May 16, 2016 12:28 pm
by Anton
Dude, that's what hammers are for.
