Will this tyre size be ok with a 2" add a leaf lift on stock rims.
Is 205/70 basically the same as the stock 195/80
235/75/15
Re: 235/75/15
charger wrote:Will this tyre size be ok with a 2" add a leaf lift on stock rims.
205/70 = 26x8
195/80 = 27x7.7
So they are smaller but wider, not a worthwhile swap IMO
- Highlander
- Can I have a tow
Re: 235/75/15
So should a 235/75 be ok with a 2" lift??
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: 235/75/15
235/75R15 = 28.9"x9.3" so yes should easily fit with 2" lift
- Edweird
Re: 235/75/15
You could almost get away with 235/75/15 without a lift couldn't you? You'd get some rubbage on lock so you'd need to do something about that.
Re: 235/75/15
I run 235/75r15, I have a calmini 3.5" lift, its just right for the tyre size with no rubbing
Re: 235/75/15
I have 235x75r15 Kumho KL-71s on standard wheels... with about 2.5-3" lift, and wheel spacers.
I wouldn't really recommend it without wheel spacers, you will probably rub your springs on full lock
I think 3-3.5" lift is best with them as you have some room for articulation!
- 217505_10150571161740122_552780121_18559213_8001371_n.jpg (80.81 KiB) Viewed 8661 times
