1600 16v on carb?
james thomas
1600 16v on carb?
Post by james thomas » Thu Nov 15, 2012 8:47 pm
has anyone ever put a 1600 16v lump in an SJ and run it on the SJ carb? can it be done?
Re: 1600 16v on carb?
Post by turbo-tom » Thu Nov 15, 2012 9:03 pm
it can be done a member on here twiss has done the conversion ;)
james thomas
Post by james thomas » Thu Nov 15, 2012 9:10 pm
cool, same adaptor plate for the 413 gearbox im guessing? whats best carb to run? i have a weber
Post by twiss » Fri Nov 16, 2012 1:22 pm
Its a beast!
I have more pics but no data allowance left on my phone!
Manifold and distributor were converted by tim pink
It did have an adapter plate on it but I changed the gearbox recently and removed it.
You don't really need it anyway.
It runs really really well!!! >:)
james thomas
Post by james thomas » Fri Nov 16, 2012 6:52 pm
what about fueling? what other parts will i need?
Post by ScottieJ » Fri Nov 16, 2012 8:15 pm
You also need to modify a dizzy housing to run the distributor off an 8v carbed motor.
To be honest if I was fitting a 16v I would go through the extra effort of running the fuel injection.
Post by twiss » Thu Nov 22, 2012 8:21 am
Fuelling - I just have a cheapy facet fuel pump... seems to work quite well!
I think a pump that does up to 4.5-5 psi may be best for the engine.
I at some point will be purchasing a high pressure pump and a regulator.
.... and IMHO injection is just more stuff to go wrong! SU all the way :)
Post by ScottieJ » Thu Nov 22, 2012 12:35 pm
Maybe but how often do you here of the mpfi system going wrong???? it's a very reliable system.
Post by twiss » Fri Nov 23, 2012 2:33 pm
Yeah the system itself may be reliable but i think it's just introducing more items that can fail...
such as £60 lambda sensors and stuff like that.... and lots of extra wiring
and you must know by now how much I enjoy deep water and injection isnt too keen on that!
Post by Edweird » Fri Nov 23, 2012 2:43 pm
Nor are carburettors really.
