Swapping fans
Swapping fans
Post by Jordi » Fri Jan 04, 2013 8:06 pm
Been offered a 1.6 8 valve.
No coil, alternator or starter but i can use 1.3 bits
No fan, it is as simple as redrilling my 1.3 fan isn't it?
Re: Swapping fans
Post by ROBBIE » Fri Jan 04, 2013 8:24 pm
Get a electric one much better
Ricky-410
Re: Swapping fans
Post by Ricky-410 » Fri Jan 04, 2013 8:28 pm
I'd use the opportunity to put an electric one on, then you can knock it off in water?
Re: Swapping fans
Post by Jordi » Fri Jan 04, 2013 8:45 pm
Cheers chaps. Not a bad idea. Any one know of a leccy fan that fits?
Re: Swapping fans
Post by ScottieJ » Fri Jan 04, 2013 8:47 pm
Water pump is the same therefore the original fan will bolt straight up!
I would recommend fitting a 1.6 rad :thumbup:
Re: Swapping fans
Post by turbo-tom » Fri Jan 04, 2013 8:49 pm
the ebay slim line cheap specials fit the biggest you can get on 1.3 radiator is 14inch as twiss has on on his , or on the vitara 1.6 radiator you can get two 9 inch ones on next to eachother :)
