I am pretty sure my Vit g16a 8v single point efi engine has a significant blockage in the internal crank breather holes leading from the crankcase up to the valve cover. This is leading to a buildup of crankcase pressure and an oil pan leak.
Can anyone advise me how to clear the blockage. I will be taking the oil pan off and resealing it. Is it ok to poke a piece of copper wire up through the breathers?
Nick
Belfast
98 Santana Vitara 8v g16a 3 door jx soft top
Can you help please? Blocked crank case breathers?
- npjrogers@btinternet.com
Re: Can you help please? Blocked crank case breathers?
Metal coathanger
