dirty head
kiwizook
dirty head
Post by kiwizook » Mon Jul 01, 2013 10:35 am
so I was cleaning my engine, and I took my rocker cover off to clean it, and seen this
left hand side
left hand side
right hand side
right hand side
what's the best way to clean this? take the whole head off, use degreaser without taking it apart? how much work, and how difficult is it to take the head off and clean and put it back together?
I also found that the oil was extermely slow to drain out like this
slowly draining oil
slowly draining oil
is there anything I should do about this, or should I just live with it?
Re: dirty head
Post by turbo-tom » Mon Jul 01, 2013 10:38 am
Yeah old engines like to coke up just whip the head off and clean it all down ;)
Re: dirty head
Post by Jordi » Mon Jul 01, 2013 10:47 am
If the engine hasn't been ran for a while the oil will have thickened up quite a bit.
Its quite surprising how much thicker it gets compared to draining a warm engine.
kiwizook
Re: dirty head
Post by kiwizook » Mon Jul 01, 2013 10:59 am
yeah, I guessed I had to take the head off. anyone done this before? how hard is it, how much work is it, any special tools required? what seals/gaskets will need to be replaced for sure?
Re: dirty head
Post by dan_2k_uk » Mon Jul 01, 2013 11:36 am
I have photos of doing my girlfriends f10a head somewhere.
A head gasket set can be had cheaply on ebay here and I presume will be cheap in NZ too and includes all the gaskets and seals you will need.
Also worth changing the cam belt and tensioner at the same time.
No special tools required although a valve spring compressor will save heaps of time and swearing.
windsor
Re: dirty head
Post by windsor » Mon Jul 01, 2013 12:14 pm
And a really good degreser will come handy and steam cleaners help save time to
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
Re: dirty head
Post by turbo-tom » Mon Jul 01, 2013 1:49 pm
As said no special tools required just some time really. The gasket shop on ebay tend to me good ;)
Re: dirty head
Post by twiss » Mon Jul 01, 2013 2:01 pm
I'd chuck the rocker cover back on, then chuck some engine flush in with the oil, run up to temp for 20-30 minutes, then turn off and drain the oil while its still warm.
This should clear most of the gunk out of it!
kiwizook
Re: dirty head
Post by kiwizook » Mon Jul 01, 2013 8:26 pm
that sounds like a good idea twiss. I'll have to get it on the engine stand, and hook it all up, but I might try that. if that fails, I might have to strip it all down and clean it, although the previous owner said it might need a new head gasket in future, don't know what he based that on, but I mighty give it a think, and treat it to a new headgasket anyways.
thanks for all the great help and replies people, this is truely a top forum :D
Re: dirty head
Post by turbo-tom » Mon Jul 01, 2013 8:37 pm
Might aswell do the head gasket whilst you got the motor out ;)
