engine ticking over lumpy:(
hamer
Post by hamer » Fri Aug 30, 2013 2:47 pm
Ever since I put 1.6 in my sammy
It ticks over lumpy so I changed leads dizzy cap and new plugs
Still lumpy so I took off each lead one by one and cylinder 1 is sparking from lead but not firing up aint had plug out butcant see Iit being plug as they new and same problem from the old :)
Iv fiddled with the timing for ages and no joy iv got it to wer it ticks over and revs up best
Any ideas guys?
Re: engine ticking over lumpy:(
Post by Edweird » Fri Aug 30, 2013 2:56 pm
Take the plug out and make sure the gap is okay.
Post by Jordi » Fri Aug 30, 2013 3:32 pm
Is the timing belt on right?
Post by ScottieJ » Fri Aug 30, 2013 7:05 pm
What spark plugs are they? Even if they are new one could be duff. So try another plug anyway.
suzukisteve
Post by suzukisteve » Fri Aug 30, 2013 9:05 pm
as mr scot said, you do occasionally get a bad one. id recommend ngk, proper job they are!
pickle power!
Post by ScottieJ » Fri Aug 30, 2013 10:17 pm
Yeah if the are Bosch throw them all in the bin and start again :hahaha:
hamer
Post by hamer » Fri Aug 30, 2013 10:47 pm
got called back to wrk only naw getting in..
they are bosh ones(super something it says on them) il swap them about in the morn see if it makes a diffrence
didnt touch timing belt as it was fine in the vitara just adjusted the dizzy
im taking it out to a pnp sun so hopefully its a spark plug :)
thanks guys
Post by Edweird » Sat Aug 31, 2013 1:19 am
The thing is it's a Japanese so why not use the Japanese plugs it was built with. Honestly, NGK BPR6E is what you want.
Bosch Super Plus and Bosch Super 4 spark plugs are over-priced guff.
Post by turbo-tom » Sat Aug 31, 2013 7:04 am
Bosh plugs are crap if we buy a motor and it has bosch plugs and leads in it the first thing we do is change them to ngk.
suzukisteve
Post by suzukisteve » Sat Aug 31, 2013 7:20 am
glad to see a few other people on here ate of the ngk persuasion :rockin:
pickle power!
