Page 1 of 2
body coulour?
Posted: Tue Sep 03, 2013 7:44 pm
by yar1950
Hi All, i'm a newbie and hope you don't mind me signing up to asked a long winded question. I bought a 2001 Grand Vitara from a dealer. I paid probably over the odds at £2325 with 92000 on the clock but it was nice condition compared to others I looked at and had the 3 month dealers warranty. The gears are very notchy and the wife can't get them in at all so it's going back for checking out on Friday. Now my question, the car is black the dealer said it has bluey/black on the logbook but I have not received the new one yet to clarify. We did a check on the vehicle and it has not been resprayed, no crashes but it is blue on the check details. When looking under the bonnet everything is like a army greyish green colour. Is this usual with the Vitara to be a different colour to the main body?
Any help appreciated.
thanks
Re: body coulour?
Posted: Tue Sep 03, 2013 8:34 pm
by mike harris
Red
Re: body coulour?
Posted: Tue Sep 03, 2013 9:02 pm
by windsor
Av never looked under a vit but when i used to work at a mot station i did notice a lot of newwer cars where left in grey primer under the bonnet and that
Re: body coulour?
Posted: Tue Sep 03, 2013 9:36 pm
by turbo-tom
bung a few pictures up and we can then go from there
Re: body coulour?
Posted: Tue Sep 03, 2013 9:44 pm
by Darrell
Well I guess you have a Z5J one
Re: body coulour?
Posted: Wed Sep 04, 2013 12:21 am
by Darrell
Code position
Re: body coulour?
Posted: Wed Sep 04, 2013 9:15 am
by yar1950
Thanks for your help chaps, Derrell that looks like the color I have, I will check the code on the car later and let you know.
Re: body coulour?
Posted: Wed Sep 04, 2013 10:24 pm
I'll check under the bonnet of our GV can't remember if its a different colour.
As for the notchy gears, check the clutch pedal where the pin goes through connecting it to the clutch master cylinder. If its anything like ours it's ovaled out so there is quite a bit of play before the clutxh starts to disengage and doesn't quite fully disengage. Also might be worth getting them to bleed the clutch system to make sure there's no air in it.
Reminds me I must get around to pulling the pedal out, welding the hole up and re-drilling it this weekend
Re: body coulour?
Posted: Thu Sep 05, 2013 7:03 pm
by yar1950
Thanks Scottie, that does make sense. I am taking it back in the morning and they are going to see if there are any adjustments they can make. I assumed it would be bleeding the clutch but I bet they don't think to try the pedal pin.
Re: body coulour?
Posted: Fri Sep 06, 2013 12:37 pm
by yar1950
Scottie, they checked the pedal today and the hole was elongated. The gears are slightly better going in now but still knotchy not smooth. Perhaps this is how 2001 vitaras are?
