Engines
b3n16
Engines
Post by b3n16 » Mon Nov 04, 2013 8:21 pm
Just because I'm curious and thinking :shock: Does anyone know what sort of straight forwardish engine swaps there are for the Vitara?. Any that use a different gearbox to the standard Vitara?. Any help or ideas would be cool.
Re: Engines
Post by ScottieJ » Mon Nov 04, 2013 8:29 pm
J20a out of a GV is probably one of the easiest. Will bolt up to the 1.6 gearbox but needs a modded flywheel.
b3n16
Re: Engines
Post by b3n16 » Mon Nov 04, 2013 8:31 pm
Being what mate?. A 2.0l I assume?. Do you use the gear box with this?.
b3n16
Re: Engines
Sorry I meant can you use the gearbox
Re: Engines
Post by ScottieJ » Mon Nov 04, 2013 8:47 pm
Yeah a 2.0 16v with 126bhp.
I edited my last post, it needs the flywheel modifying, the crank bolt patterns are different and a section needs to be machined flat. Apart from that it bolts straight up to the 1.6 gearbox, will need to make new engine mounts and there's quite a bit of wiring involved as well, however the 2.0l has a separate engine harness so that makes life slightly easier.
b3n16
Re: Engines
Post by b3n16 » Mon Nov 04, 2013 8:49 pm
Would it be worth it or is the change not that noticeable?.
Re: Engines
Post by ScottieJ » Mon Nov 04, 2013 8:55 pm
Here's a pic of what needs to be done to the flywheel inner bolt holes are the 1.6 outer 2.0
It's a pretty much unheard of conversion over here to be honest but it's almost 1/3 more power and torque. I'm planning on replacing my 1.6 8v in the Sj with one, have it in the workshop already :mrgreen:
What 1.6 is in yours at the moment?
b3n16
Re: Engines
Post by b3n16 » Mon Nov 04, 2013 9:27 pm
I really don't know if I'm honest. I think it's the 1.6 8v :S
Re: Engines
Post by donkeychomp » Mon Nov 04, 2013 10:18 pm
Put up a piccie...then we'll know!
Re: Engines
Post by twiss » Tue Nov 05, 2013 4:01 pm
1.6 16v is a good engine! easy as well in a vit i would guess!
Not really worth the effort though unless you get the engine for peanuts!
