Pump ?
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sat Dec 13, 2014 4:14 pm
Thanks for the help lads i shall order that one today , hope i get that idiot proof guide wif that on jordi lol , just a quicki could i put it under bonnnet or does it nee to go near tank ? and could i connect some sort of gauge for my dash to keep a eye on pressure , thanks
Rhinoman
Re: Pump ?
Post by Rhinoman » Sat Dec 13, 2014 4:18 pm
Usually they need to be near the tank because they are 'pusher' type pumps, there should be fitting instructions with it which should state how high it can be mounted relative to the tank.
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sat Dec 13, 2014 7:00 pm
Spot on mate i will see when it comes thanks for the help
Re: Pump ?
Post by Darrell » Sat Dec 13, 2014 7:58 pm
I expect it will want running via a relay fused straight off the battery.
You can wire them in with the oil pressure switch so it stops running if the engine has stopped but I believe you need a special oil pressure switch for this, as it needs power to start in the first place.
Wondering what people do for a filter ??, can you still use the original filter before the new pump.
I assume it won't handle the pressure if fitted after the pump. I'm sure you could fit a aftermarket filter that would though.
Rhinoman
Re: Pump ?
Post by Rhinoman » Sat Dec 13, 2014 8:06 pm
Use a high pressure filter, a Vit one would be OK. You should run it off a relay controlled from the ECU as per the original 16V wiring, that maintains the Ignition fail Safe function.
Re: Pump ?
Post by Darrell » Sat Dec 13, 2014 9:04 pm
Ignore the instructions that come with the pump.
Mr Rhinoman's right, as your using the Vitara loom :thumbup:
Vitara SPI System.jpg (534.2 KiB) Viewed 6378 times
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sat Dec 13, 2014 10:31 pm
thanks lads so on the diagram 30 is the fuel pump relay , I just connect up to that ? , just to check how will I know which 1 is which , thanks
Rhinoman
Re: Pump ?
Post by Rhinoman » Sat Dec 13, 2014 10:35 pm
You need to follow the schematic that is in the FSM here:
http://www.rhinoman.org
Its a few pages on from that system diagram.
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sat Dec 13, 2014 11:42 pm
spot on mate think I followed it right fuel pump relay A20 - p = pink wire
lukey4x4
Re: Pump ?
Post by lukey4x4 » Sun Dec 14, 2014 6:01 pm
Sorry to be a pain lads a was having a look today to see if i could find this relay fir the fuel pump av got bout 4 relays n havnt a clue which 1 i need ,and what is this from petrol tank
