Su carb snorkel air filter
Josh-holden
Post by Josh-holden » Sun Apr 12, 2015 1:02 am
Hi, what and how are people useing air filters on there su carbs with a snorkel attached? Any pics would be great
Re: Su carb snorkel air filter
Post by Anton » Sun Apr 12, 2015 12:13 pm
I had a cone filter on the top of my snorkel before I removed it. When I refit it, I'll probably do the same, or maybe I'll fit a factory "doughnut" airbox for an SU, as they sit in such a way as to not really get in the way.
d_r_1989
Post by d_r_1989 » Sun Apr 12, 2015 3:57 pm
You can buy off ebay the adapters that bolt to the su and the other side is round for you to fit some pipe and clamp it, whether that's filter in the bay or on top of the snorkel. If that's what your meaning?
Josh-holden
Post by Josh-holden » Tue Apr 14, 2015 7:19 pm
I mean where to put the filter as wouldn't the cone filter get soaked in the rain/ puddles if it's on top
kibris
Post by kibris » Wed Apr 15, 2015 9:30 am
I've just bought one of these for the top of mine
http://www.ebay.co.uk/itm/SNORKEL-TOP-W ... 6016.l4276
Post by ScottieJ » Wed Apr 15, 2015 10:18 am
I wouldn't put a K&N style filter near any vehicle of mine, especially on an offroader. Even the genuine K&N ones don't filter well and allow loads of crap through into your engine.
I would run the snorkel into the standard airbox and then into the SU. Having a bare filter on top of the snorkel open to all the elements isn't a great idea really.
Post by dan_2k_uk » Thu Apr 16, 2015 8:00 am
I've just moved the standard air box slightly further down the wing and plumbed the SU up to that.
Post by Anton » Thu Apr 16, 2015 9:39 am
Thinking of getting one of those. The SU fits in the middle, then a small elbow directs air down and into the SU. Then I'll attach the snorkel to the other end.
It's made for a 1300 Mini though, might not have enough flow for a 1600.
Josh-holden
Post by Josh-holden » Thu Apr 16, 2015 12:28 pm
Ok, I think I'll try and get the standard air box to fit, iv got a fuel pump there though so will have to move it somewhere
Josh-holden
Post by Josh-holden » Sat Apr 18, 2015 9:41 am
Is it ok to route some pipe to the other side of the bay to the air box then out to the snorkel? Would this reduce the air flow?
