sj413 with 1.6 engine. what alternator to use?
- Josh-holden
i have a 413 sj, it has the 1.6 vitara. I need an alternator for it, is there a uprated one? where's the best place to get one from? its got the ribbed aux belt not the v belt
Re: sj413 with 1.6 engine. what alternator to use?
I just run a standard Vit alternator to match the engine.
- Josh-holden
ok, does anyone know what amp the alternator should be 1.6 vit engine? 50 or 70?
I ran the 1.3 alternator as it matched the plug
- Josh-holden
mine has the round plug with the ribbed belt. i think its 50 amp. i think the part number is LRB00125. these are about £135. do you know anywhere i can get it cheaper or a second hand one?
- Josh-holden
also, would i be able to run the 70amp alternator?
Just to add, I would recommend using the alternator with the internal fan, kinda like this
Rather than an external fan like this
The external fan seems to pick up water and spray it everywhere
1.3 or 1.6 either one will work apparently
