Bowser. LWB on 33s
Post by ScottieJ » Sat Jan 14, 2017 10:51 pm
Back to work on this one finally :armsup:
Started work on the bulkhead, I'm gonna run 31s but want enough room for 33s as it's probably going to happen at some point :lol:
Ignore the fact the plate doesn't go to the bottom, I'm going to re do the sills, either gonna tuck them like on the blue one or just go box section.
Should get the other side finished off in the week hopefully
Also this is getting the j20 again now, mated to a 2wd x90 gear box that I'm going to modify to move the gear lever and then it should fit the standard transmission tunnel. This bolts straight up to the j20 with a baleno j18 flywheel and has a black diamond clutch fitted. I will also need to make a custom prop to mate it to the tbox.
Post by andyrew » Sat Jan 14, 2017 11:19 pm
Sounds like an interesting combo, is the x90 not just a g16 lump?
Post by ROBBIE » Sun Jan 15, 2017 9:27 am
Not going twin t/box?
Post by ScottieJ » Sun Jan 15, 2017 7:17 pm
andyrew wrote:Sounds like an interesting combo, is the x90 not just a g16 lump?
Yeah the G16 has the same bellhousing pattern as the j series engines, however the crank has a different bolt pattern, after a lot of research I found out that the j18 flywheel is physically the same size as the g16 flywheel but obviously has the right bolt pattern for the j20. Finding a j18 flywheel wasn't easy mind :lol:
ROBBIE wrote:Not going twin t/box?
Nope, that's being kept for something else ;)
Post by andyrew » Sun Jan 15, 2017 8:23 pm
Handy that its basically bolt on rather than loads of machine work being needed.
Im going to guess the 2wd x90 box has a better gear / final drive ratio to go with the j20 lump. Otherwise id have thought using the sami box on an adapter plate would have been the solution.
Post by ScottieJ » Sun Jan 15, 2017 9:20 pm
It's the clutch I was concerned about, a 1.3 clutch probably won't cope with 128ft-lbs :lol: I have thought about giving it a go though, I just want a clutch that isn't on or off.
I still have a few mods to make for it to work but they aren't that complicated.....hopefully :lol:
Post by Anton » Mon Jan 16, 2017 9:32 am
It's also going to be a lot cheaper than a dual plate clutch or a paddle clutch when it wears out...
Post by ScottieJ » Tue Jan 17, 2017 8:46 am
Anton wrote:It's also going to be a lot cheaper than a dual plate clutch or a paddle clutch when it wears out...
True that, plus you don't loose torque by having to run a light 1.3 flywheel, the weight difference between the 1.3 and 1.6/1.8 flywheel is quite a lot, pretty sure the 2.0 is even heavier.
Got the over side of the bulkhead sorted, just need to work out what I'm going to do with my sills now :hmm:
Looks good on 33s don't you think, I won't be running these on it though.
Also started working out how to fit my swift gti seats last night, looks pretty simple tbh.
Post by ROBBIE » Tue Jan 17, 2017 9:04 am
Tuck those sills boy
Post by ScottieJ » Tue Jan 17, 2017 11:02 am
I don't want chassis mounted sliders on this one, otherwise i would, I've been thinking either 100x50x3mm box section sills or maybe even making my own new sills out of 2-3mm
