Lwb Santana 1.3 Hif44
Re: Lwb Santana 1.3 Hif44
Post by Rankine » Sat Jul 05, 2025 9:10 pm
Managed a few hours today at the garage, got the rear brakes plumbed up and fitted a extended flexi from the chassis to axle. Also got some rear arch and bump stops fitted.
They cover the road wheel's completely but not the offroad ones. Was a option for 100mm but went for 70mm
Post by Rankine » Fri Jul 11, 2025 11:39 pm
Bit of a carry on but the brakes are on and have given them a quick bleed still need another go probably. I've also went back to a standard brake servo.
4 diy bumpstops fitted to the previous person's spoa perches, changed my fuel tank just filters to swap again. Then it should be ready for a day out on 20th
Post by Rankine » Mon Jul 14, 2025 11:24 pm
Getting closer to drumclog! Reckon its pretty much good to go. Not got my handbrake connected up yet. But filters changed, everything under bonnets connected back up. I've put the right oil in the carb.
But tonight I finished the body work for this round. Not needed for clog but wanted it this far. 4 wheel arches trimmed and fitted. Painted the arches with my close but not close enough cans. And redid the stripe along bottom of doors/quarters.
Petty happy with how it looks right now. Will get a hand giving the brakes one last bleed. Then give it a test drive.
nanno
Post by nanno » Thu Jul 17, 2025 1:57 pm
Plenty of room for activities with those wheel arches!
