The Sexuki
Re: The Sexuki
look like bull bar mounts russ
Re: The Sexuki
me neither just guessing
- Edweird
Re: The Sexuki
I reckon that's what they are. They're in the right place for them anyway, and mine has similar things too, as I've left the twisted mounts on for now.
Re: The Sexuki
Cheers dudes!! Made me
Correctamundo they are bull bar mounts, thought it looked a bit gash so I left it off!!
Might put it back on because it has got some nice spot lights
Had the battery light and exclamation mark light on all week.... Had a fettle with the alternator, took it apart, couldn't see anything wrong, put it all back together, still the same!
Thought I would try a new fan belt, the one I had on it was a touch too long and was not far off the limit for the adjuster, tight though, not squealy.....
Bingo, off goes the light... Very weird
- Edweird
Re: The Sexuki
Maybe it was slipping so much it didn't squeak or something......
Reminds me, I still need an alternator mount...and I still need to sort out that fuel problem. I think it's something wrong with either the carb, the pump or the tank.
Re: The Sexuki
What does it do wrong Ed?
- Edweird
Re: The Sexuki
It splutters badly, where you lose power and get it back again repeatedly within a second or two (sometimes longer) without moving your foot on the pedal. It cuts out completely on some occasions. It's worse uphill I've noticed too.Sexuki wrote:What does it do wrong Ed?
I'm thinking next stop the carb needs a clean out and service.
Re: The Sexuki
Mmmnnnn sounds like it!
Have you changed the filter?
- Edweird
Re: The Sexuki
Yeah, I changed it. It was full, completely full, of shit.
