broken props
broken props
if you brake a rear prop would it be ok to remove it and drive in 4wd??
Re: broken props
Well I wouldn't recommend it but I have seen people do that without a problem. I know if the prop failed that's what I'd do to get home..
As long as it's just the prop and nothing else :IE just a UJ collapsed.
- Highlander
- Can I have a tow
Re: broken props
I drove one on the road for a year like that with no probs.
FWD SJ
Its now got a new prop and is back on offroad duty
FWD SJ
Re: broken props
Well that answers that oneI drove one on the road for a year like that with no probs.
Re: broken props
cheers guys its not me its the son-in-laws jimny we took the rear off last week because the sliding joint has broken. so hes been using it in 4wd but now the t/box seems to be on its way out
- Edweird
Re: broken props
Well, the forces on the t-box will be coming from a different direction when in front wheel as opposed to rear, maybe SUzuki skimped on bearings or something with the Jimny
Re: broken props
Jimny boxes aren't as strong as SJ ones as they are chain driven. Should be able to pick one up cheap enough as a lot of people upgrade them to sj transfer boxes
Re: broken props
I've found my SJ becomes very wheelspin happy when only on the front prop!
Re: broken props
thanks for all the replies we got a replacement box all sorted now seems you cant use a jimny as front wheel drive and tow a trailer
Re: broken props
And tow a trailer
I like the way you missed that bit out originally
