lock right diff
Re: lock right diff
not at all! it's not my fault the tail happens to try overtaking me on roundabouts late at night!
Re: lock right diff
I have had both a lockright and a welded diff.
Lockright waits until the worst possible moment and then locks causing the back to snap out of line. It never lasted more than 20 miles at a time in the racer(I am perhaps a little harder than most on components)
Welded diff is predictable and gives superb traction, useless on tarmac.
If the SJ is going to see ANY tarmac do not weld the diff, off road only it is cheap and reliable if done properly
Tim
Tim
Re: lock right diff
adamsj wrote:do they completely lock the diff up like welding it and are they safe.and has any body welded a diff.what are they like to drive with
i hacvnt read the entire post and dont intend to,
i had two in my landcruiser, and to be honest, theyre shit.
if you drive on the road, they torque steer and torque break under engine breaking, and at high speeds its bloody scary in a tall un-stable truck! off road, the lock sometimes or you just hear them clicking, then you have to drop the revs and the wellie it againto get it to lock!
the front well, thats awesome if your climbing up a hill, if you using engine breaking, they lock up and you cant steer, its a nightmare.
id only run one in the front in desperation or if i got one really cheap as you can unlock the hubs and its ok, the rear, off road only its great, on road leathal.
save your money and just put in a rear air locker, heaps better.
if you look at any challenge truck, nobody runs lockrights or quaifs, if your comp racing a quaif is the way forward, if your off roading, air locker all the way.
Re: lock right diff
i dont understand why they dont put limited slip diffs in 4x4.it would be so much easyer and surely it would work
Re: lock right diff
i know that on drift cars (probably the same for 4x4's though) it would be better, but decent ones cost loads of money! plus even on road they're quite unpredictable compared to say a welded unless you spend "miwyunz" on a super duper 2-way one.
Re: lock right diff
They do, in some of the more spendy trucks. There was a vitara that had one, I *think* (or maybe a grand vitara) as an extra-cost option, I'm pretty sure you could get them in Land Cruisers too.adamsj wrote:i dont understand why they dont put limited slip diffs in 4x4.it would be so much easyer and surely it would work
The thing is, they're not *much* better than an open diff offroad unless you're talking a clutch type, which has it's clutch set very tight. LSD's are really best for road vehicles, for offroaders you want a locker of some kind.
In the end it's all down to money, and what sells a vehicle. 99% of 4x4 customers don't understand what a diff even is, and so won't base their purchase on whether this vehicle or that vehicle has a superior one.
So the manufacturers don't bother fitting them in most cases.
If 4x4's only got sold to people who actually offroad them, they'd probably all have lockers as standard. As it is, you don't need a locker or an LSD to get you out of Tesco's car park, so the vehicles are built with that in mind.
- Edweird
Re: lock right diff
They tend to be fitted to the sportier vehicles that can spin up easily. My dad fitted an LSD from a Cosworth Sierra in mum's old 2000E Sapphire when I were wee tot. According to both of them it made it a little more fidgety in the dry because it would make it skip when it wouldn't normally (because it didn't have the guts), but it wouldn't spin up in the wet like it used to. Even my zook, all forty horses of it, can get sideways on wet roundabouts and spin wheels on junctions.
LSDs tend only to be fitted to cars with the umph to spin up on dry tarmac.
Re: lock right diff
I've been told that an LSD is the way to go if you do a lot of driving on snow and ice...
Re: lock right diff
Does anyone know which arb lockers fit the rear of a 410? Thanks
Re: lock right diff
I don't think ARB make a locker that fits 410s. Only 413s and samurais.
