steering Z bar
Highlander
steering Z bar
Post by Highlander » Wed Jun 06, 2012 1:45 pm
After bending ANOTHER one this weekend I really do need to get a quality one! :)
Whats everyone else using?
Mine is standard SPOA with no extra lift
Re: Steering Z bar
Post by ScottieJ » Wed Jun 06, 2012 2:17 pm
Might be more than you want to spend but the only true solution in my opinion http://www.rsmfg.co.uk/page15.html
Re: Steering Z bar
Post by twiss » Wed Jun 06, 2012 4:55 pm
Get mercedes steering arms... you bolt them on with your brake caliper mounts and give you nice easy OTT steering :)
I couldn't tell you which mercedes they come off though!
Re: Steering Z bar
Post by ScottieJ » Wed Jun 06, 2012 5:02 pm
twiss wrote:Get mercedes steering arms... you bolt them on with your brake caliper mounts and give you nice easy OTT steering :)
For an offroad only low speed vehicle maybe, the Tre's have different tapers to suzuki Tre's and this results in barely any surface contact. I would not advise it on any road going SJ!
a thread with measurements etc. http://www.zukikrawlers.com/showthread.php?t=22075
Re: Steering Z bar
Post by ScottieJ » Wed Jun 06, 2012 5:19 pm
well unless you make a new steering links with mercedes Tre's :thumbup:
Re: Steering Z bar
Post by twiss » Wed Jun 06, 2012 5:21 pm
Yeah as scott points out I think most people use different tie rods.
My mate who's got the merc arms on his has a different tie rod that's about the same length as a suzuki one
Highlander
Re: Steering Z bar
Post by Highlander » Tue Jun 26, 2012 5:05 pm
I'm going with the Merc steering arms and TRE's
Been trawling the Merc forums to find the right ones, the off road forums are full of dodgy info! :hahaha:
They are actually called steering arms and are fitted to the 126 Chassis which covers these models :
Model numbers in BOLD
Part 11 on this picture (they are handed left and right)
These are the Mercedes part no's (if you want new ones)
STEERING ARM LEFT - A 1163321620
STEERING ARM RIGHT - A 1163321720
This is one fitted on a Suzuki, it bolts to the caliper holes but needs slightly drilled out to fit and longer bolts.
The new bolts need to be :
M12 x 1.25 x 50
M12 x 1.25 x 60
They are different lengths, you will need one of each for either calliper
I'll add some pics as I do it
ianedwards
Re: Steering Z bar
Post by ianedwards » Wed Jun 27, 2012 1:26 pm
if you do, it would be great to see how you do it,
Ian
Ian. :)
Highlander
Re: Steering Z bar
Post by Highlander » Fri Jun 29, 2012 10:41 am
Wee update :
Steering arms can be had here (big Merc breakers)
http://www.mercman.net
£10 each plus vat :D
One of the ebay breakers I asked wanted £50 each plus postage!! :screwy:
They are £41 each new from Mercedes :D
justaddmud
Re: steering Z bar
Post by justaddmud » Sun Mar 03, 2013 9:02 am
I think that merc arm is such a good idea compared to the horrid Z-Bar
I was going to do it using only 1 arm by making a new drop link and leaving the existing tia bar in place on the original mounts, in theory to make the drop link all I needed was 2 rod ends (one for SJ and one for Merc) a beefy bit of Dom and someone to cut some threads in either end so that the rod ends could also be changed when they wear out too.
£10 each, that makes for a cheap decent conversion
