suzukisteve
- Suzuki Guru
Post
by suzukisteve » Wed Jul 04, 2012 9:57 am
morning everyone! hope everyone is cool
just a quickie, how easy is it to whip out the tank on my 410? any ideas on time?
finally gettin off my a*se and doin something
gonna give the tank guard a lick of paint while its out too i tink
pickle power!
Highlander
- Can I have a tow
Post
by Highlander » Wed Jul 04, 2012 11:34 am
Depends if anythings seized or not
there's not much holding them in really, pretty self explanatory once you're underneath.
half an hour should do it no probs
- The Boss
Post
by ScottieJ » Wed Jul 04, 2012 12:05 pm
Highlander wrote:Depends if anythings seized or not
what he said! + once all 4 bolts are undone, lower it on a jack slightly so you can undo all the pipes before lowering it to the floor. most of the time the pipes from the tank are a bit fragile!
Post
by twiss » Wed Jul 04, 2012 12:40 pm
ScottieJ wrote:most of the time the pipes from the tank are a bit fragile!
read as: made of rust
- The Boss
Post
by ScottieJ » Wed Jul 04, 2012 12:41 pm
twiss wrote:ScottieJ wrote:most of the time the pipes from the tank are a bit fragile!
suzukisteve
- Suzuki Guru
Post
by suzukisteve » Wed Jul 04, 2012 1:32 pm
lol made of rust indeed!! Basically some (alot) of welding is being done bu the fuel filler. i guess it would be best to drop the tank.
unless you guys know any sneaky (but safe) way of doing it without dropping the tank?
pickle power!
- The Boss
Post
by ScottieJ » Wed Jul 04, 2012 1:52 pm
suzukisteve
- Suzuki Guru
Post
by suzukisteve » Wed Jul 04, 2012 2:20 pm
brill! i was thinkin rags and rubber glove but wanted to make sure that my online wealth of knowledge
(you guys) agreed
she'll be welded up before ya know it!! whoop!!!
pickle power!
suzukisteve
- Suzuki Guru
Post
by suzukisteve » Thu Jul 05, 2012 10:41 am
welding done!! some on drivers door, front outer wing and rear floor near fuel filler! looks the nuts! i have to confess i didnt do it tho. a mate with a workshop done it.
also removed the f*cked front bumper. made some brackets up for the side lights/ indicators and mounted em on the tubular bar that the front bumper mounted onto.
next month:
bottom of the roll hoop (if u get me)
sort arches out, maybe virtual lift??
pickle power!
- The Boss
Post
by ScottieJ » Thu Jul 05, 2012 10:42 am
pics man pics
and a build thread to go with them
