disc rear axle
Jay30685
disc rear axle
Post by Jay30685 » Tue Oct 02, 2012 9:30 pm
Right guys, I'm doing leaf over spring so I'm going to have my axles off, I've got a spare pair of axles that I can do the work on to make it a straight swap.
I'm wanting to weld the rear diff up and build the axle to have rear disc.
Can anybody tell me what I need? I've got a spare pair of axles so have calipers etc. Would like to do it as cheap as possible
Re: disc rear axle
Post by dan_2k_uk » Tue Oct 02, 2012 9:36 pm
From front- Caliper carriers. Brake hoses. Wheel studs.
From rear- old drums to cut centers out of.
There is a guide in the diy section on the home page.
dazerede
Re: disc rear axle
Post by dazerede » Wed Oct 03, 2012 8:34 am
Hey mate there is a nice set of 410axles on ebay with welded diff and a rear disc conversion I would bid but its 205 miles away from.me
4” calmini lift kit :)
Jay30685
Re: disc rear axle
Post by Jay30685 » Wed Oct 03, 2012 5:29 pm
What's difference with 410 axle?
Re: disc rear axle
Post by Edweird » Wed Oct 03, 2012 7:04 pm
Diff ratio...
Re: disc rear axle
Post by ScottieJ » Thu Oct 04, 2012 9:37 am
Edweird wrote:Diff ratio...
+ narrower+different spring spacing :thumbup:
Re: disc rear axle
Post by Edweird » Thu Oct 04, 2012 1:41 pm
Thank-you Scott.
Re: disc rear axle
Post by ScottieJ » Thu Oct 04, 2012 3:37 pm
:thumbup:
I should say against a samurai axle. 413 axles are the same width and spring spacing as 410 axles but have samurai sized diffs and a slightly lower ratio.
Here's the :suzuki: axle bible http://forum.suzukiclubuk.co.uk/vi ... 12/t,2801/
4x4edd
Re: disc rear axle
Post by 4x4edd » Tue Oct 09, 2012 9:56 pm
I'm also doing this on my new axle as my old one collapsed where someone had done some shocking welding :pissed: :pissed:
But got a quick question. What's the best way of getting the drum brake casing off the shaft? I don't want to damage the bearings as they look new, but don't want to cut the casing.
Any suggestions?
Re: disc rear axle
Post by Darrell » Tue Oct 09, 2012 10:11 pm
How did you get to see the bearings when the drum is still on the shaft. You need to undo the 4 bolts behind the drum to remove the shaft :er: :er: :er:
Normally the drum is removed with a slide hammer, but the shaft is still in the axle.
